Ok in short my car will not start. It is so much more then that because it is acting really strange. It will only start when one plug is out. I was running through troubleshooting proceedures (checking spark, fuel, compression etc.) and I had Spark and fuel. I can't check compression since I have no compression tester.
The car started when checking spark in cylinder one but not with the plug in the hole.. What is going on? What should i look for please please help this is my only driveable car and I have work tuesday. PLEASE> :icon_conf
ps. I also checked to see if I had some ground issue between coil plate and head. I have continuity.
