Need Help Installing Oil Pressure Gauge
10secdream
Got Boost?
Sep 11, 2007
767
Edmonton, Alberta, Canada
Well I just got my Prosport gauges from the recent group buy and was wondering how I am going to install the oil pressure gauge. My car is a JZA70 and from factory it never had an oil pressure gauge.
I was wondering if/where there are any oil galleries that I can plug the sensor into on the 1JZ. Also, for those who have installed oil pressure gauges how did you do it?
Thanks,
Steve
RWHP
Going for 1JZ
Jan 14, 2008
126
Ostersund
Can't i splice the oil pressure wire (there is 2 i think) and use it to get a signal for an aftermarket oil pressure gauge?
Clip
The Magnificent Seven
Oct 16, 2005
2,738
9
Virginia
i suppose you could but im not sure the stock sending unit is as accurate as an aftermarket. kinda like our water temp gauges - im not sure if its the sender's fault or the gauge's fault.
10secdream
Got Boost?
Sep 11, 2007
767
Thanks for the help guys. I was hoping that there would be an easy to access oil gallery hole on the block. I have some fittings that I was going to try but it looks like I might have to get the sandwich plate or the driftmotion fittings.
