Any help will be much appreciated. Please don't bother if you're just going to bash this thread.
I've been working on my 1JZ swap in my 89' turbo shell. I work 6 days a week and about an hour or so on my day off. So I barely have time, but I feel like I'm getting close to finishing and I just want to drive it before the snow comes.
I got my wire harness extended done by phenoix tuning. Did a great job.
Been searching and researching and I can't seem to find the answer to them. Some of the links are down.
I'm having trouble either locating where the plugs go for the wiring harness, or what parts I'm missing exactly. So far I have most of the parts to complete the swap for a non-front clip.
Also I just got some non-abs brakes lines. Can I just disconnect the abs ecu and pull it out?
Motor and trans (R154)
2jz water pump
CX FMIC
driftmotion slave cylinder ss line
" " high pressure ps ss line
ps reservoir
dual electric fans
CX radiator
etc.....
Here are some pics and maybe it can help explain better than I can.
Quick pics of my progress so far.....
If you guys see anything missing please let me know. Certain parts I just kind of have it laying around somewhere. If anyone has a remedy for this. My core support is bent and now the bolts won't line up for my radiator support.
Do I need this particular part. Idle air control valve? If yes, where does it go?
These plugs are located on the driver's side front near the headlights. Plugs for headlight?
This came off the intake manifold. Just can't find the plug/harness for it. Absolutely no clue
These wires were cut when I got my shell. (2 white wires spliced together)
Body plugs. I'm not sure if I need those.
No clue
Unsure where the lines go. Same for the one sticking out of the fire wall
Body plugs passenger side near the front.
Where does this run too and what is it?
This one I'm confused on. Like everything else on this build. When I searched some say yea it's for an MK3 1JZ others say it's for a soarer. I believe it's the right one, but I'm unsure where the pigtail goes
This plug is behind the glove box. I can't find where it would plug into though
2jz water pump
CX FMIC
ps reservoir
dual electric fans
CX radiator
etc.....
No clue
