Im not sure if this has been discussed but I have a really high pitch scream/noise from under the hood on the drivers side. I checked a lot of things but I just cant seem to figure it out. At first it only happened at starting at 3500 rpm and up at open throttle. The noise is linear and only under load. Now power is being robbed and happens all the time at half throttle starting at 2500 rpm. Im getting boost but after 4000 power just drops off. Could it be an alternator pully bearing. I checked the turbo but its fine. All belts are taught. Maybe perhaps a leak in my IC hose, I dont know. Please help. I figured I ask the pros on this one. Any suggestions would be greatly appreciated.
