ok guys heres the thing im having problem with vacume lines im not getting any vacume on idle to my stock FPR, also is there supposed to be vacum on the top 2 outlets on top of the T/B....before i run it lean i need to know thank you
Check your vacume hoses, are they worn out? Replace them if so. On the TB you're talking about the two skinny vacume inlets right? Yes they are suppost to have vacume, that's what they're there for .
if you arent getting any vac at the fpr i would look at the vsv. bypass it and see if that fixes the problem.
btw, if you dont know the vsv = vacuum switching valve. its the little box thing w/ a 2 wire connector under the intake manifold. has a vac line on each side of it.
