Need help fast
Status
Not open for further replies.
splitzhail89
Banned: Scammer, liar, cheat and thief
Jan 11, 2006
Nampa, Id
Hello, finally got everything for my car, got it to turn over, but it just wont fire. It doesnt have spark, and i pluged a diode into the injector clip, and there is nothing there either. Somebody please give me some info.
-Adam
IHI-RHC7
"The Boss"
Oregon
OK. Define what you mean by
If you have no power, then you need to start checking circuits, if the fuses are good, are they energized?
splitzhail89
Jan 11, 2006
Nampa, Id
alright, wont spark, the diode wont light up, fuses are good, so i need to check circuits power, and the system is energized. I will get back to you tomarrow, it is really just stumping me.
-Adam
johnathan1
Supra =
Aug 19, 2005
5,056
make sure all connectors are plugged in, and check the igniter...
Also, make sure to check the condition of the wiring, a wire may have broken off from a connector if the car was being worked on, this was the problem i was having,...
mk3713
Up for sale
Nov 29, 2005
97
Houston
Does your check engine light turn on. If it does not than it sounds like it could be the EFI main relay. That is what was wrong with mine it had me stumped for almost 20 minutes after engine rebuild. It runs fine now.
splitzhail89
Jan 11, 2006
Nampa, Id
No engine check light, and that is what i have done with it is a full stock rebuild plus metal headgasket, and arp head studs. New wiring harness so i dont know why wiring should be a problem. I am just stumped, all the fuses are good, and it just will not fire. Has no spark, and no power to the injector clips. that is all i have to say.
-Adam
jdub
Feb 10, 2006
10,730
Valley of the Sun
Check your plugs going to the ECU...you CAN plug one in the wrong place. I've got the Dunce cap to prove it. Causes all kind of weirdness.
IHI-RHC7
"The Boss"
Oregon
ok...
What this tells me is that your ignition switch is broken, or not getting power at all. If other things work, starter, etc...
It would seem that either the switch is bad, or wire connector B1 is not making good contact.
bluemax
The Family Man
Orange County, CA
I'd check for power at the EFI fuse receptacle if the fuse is not blown.
It'll till you if the problem is before the fuse if you don't get power.
Hopefully the problem is before the EFI fuse.
Status
