Need a bit of help. I bought a '91 Supra that was converted to a 5spd transmission by the PO. I need to return the clutch safety switches back to normal for an inspection before I can license the car. The problem I'm having is am not sure how they are supposed to be wired. I have been reading a lot of the TSRM and it isn't very clear. From what I can gather, there are two switches on the clutch. One that is depressed as you press the clutch in all the way that allows you to start the car and another switch that if you press in the clutch will cut out the cruise control.
I think the Cruise control safety switch is wired to the cruise control ECU, but I'm not 100% certain.
The safety start switch I have no idea where it goes.
Any help would be appreciated. If anyone has their interior apart and can take some pictures, that would be great.
Thanks!
Thanks!
