Need Help, 6th valve no pressure
Jun 23, 2005
14
Innisfil
Did a pressure test and all the valves came out relativly fine except for 6, it read only 20 pounds of pressure, need possible problems that may not involve ripping the sucker apart.
Any suggestions would be greatly appreciated.
Thanks
Kyle
mrnickleye
Love My Daily Driver !
Jun 8, 2005
825
Mojave Desert, Ca
I assume you mean #6 cylinder that has 20psi..... Does the engine run?....Perhaps one of the valves is too tight on #6, or you have a burnt exhaust valve.. Whats the compression on 1-5 cyls ??? I gotta know to help....After you post the #s, I'll give you some info.
Jun 23, 2005
14
Innisfil
Here are the numbers that i got.
190, 190, 210, 200, 210 AND # 6 CYLINDER IS 20 LBS
The car does run, however I can not get the rpm to rise above 3K at best. everything else seems to be in ok condition, and the car is an 88 turbo model if that helps with the info.
Thanks
Kyle
May 31, 2005
111
Omaha
Sounds like you have a stuck open exhaust valve or are missing an exhaust valve (or part of one) or have a hole in your piston. I would go with the valve problem though...happened to me on #6 with a motor that had 2K miles...
Trev
mrnickleye
Jun 8, 2005
825
Mojave Desert, Ca
Probably stuck open valve. But....Pull the spark plug out, and put a 19mm socket and ratchet on the crank bolt to bring the piston up to the top. Use a very bright flashlight to look into hole, and maybe you might see a hole in piston(most holes will be at spark plug because that is what would burn the hole there).
If you can't see, take a coat hanger and poke around on the piston top to see if it suddenly goes way in (hole). Probably not hole.
Pull valve covers off and check that valves are working properly. Yes?? then likely a very burnt valve.
