Need help 1j guys!!!
got-sc?
17
tucson
ok i got a single turbo 1jz motor in my sc300 and we just finished the wiring on the car. the car runs great with the TPS sensor off and when i put it in it runs like shit. i get throttle cut and the map doesnt work when its plugged in. i need both the tps and the map to work when i get ready to dyno tune cause i know not having the tps sensor is sketchy and can lead to rod knock. So have any of you guys ran your 1jz with no TPS and tuned it, and is it running fine?? Any suggestions???
