Just installed some hardpipes and a fatty front mount and now Im hitting fuel cut while still running crazy rich. Ive got a Lex AFM, 550s, Walbro, AFPR, running 20psi on a 60-1 upgraded CT. Im tuning with a S-AFC. Ive got the fuel pressure around 38psi with the vaccum line off, and Im -20% across the board on the hi-throttle map on the AFC. So what the hell do I need to do? Lower the fuel pressure? the boost (last resort)? Take more out on the AFC? I need some help NOW!!!!! I was fine, not hitting fuel cut (but still crazy rich) before the hardpipes and FMIC, but now Im all over fuel cut. Any help will be appreciated. Thanks.
