Ok so my build is all togethar. I had the block completely machined and put in JE pistons and rings, Eagle rods, Arp rod bolts, and cleavite bearings. the head was rebuilt by toyota and the machine shop double checked the surfaces. 1.5mm titan metal head gasket, with arp head studs. New oil/water pumps from toyota. New walburo fuel pump. The turbo is stock. The stock airbox(need to get an adapter plate). Intercooler is stock. I have the stock turbo elbow and an ebay stainless downpipe thats 2.5 at the elbow to 3" pipe. Turboxcess boost controler. Autometer boost gauge. NGK plug wires. Apexi SAFC untuned. w58(i think thats the non-turbo tranny) with a centerforce dual friction clutch. turbo LSD rear end. The car is a combination of years, its a 87 turbo hardtop body and body harness, 89 interior and tail lights, and a 88 7mgte motor, ecu and harness. What do you guys think i can do power wise and 1/4 wise with this set up. What boost do you guys think I should set it to? If i weld a bung on the downpipe and put a Innovate LM-1 on it what should i tune it to with the SAFC? Were are the biggest cheapest gains for me at this point? all input will be most apperciated.
