need elec advice
madseacow
360
Buda, Tx
I'm looking for some information to get me started on buying electrical components. I have a jdm 88t with BPU, Turbo Timer, EBC, Boost gauge, and A/F gauge (light show) I am just finishing BHG repair and had a valve job/P&P. I don't ever plan on replacing or upgrading turbo. I do plan on going FFI with a larger TB. I believe I want to go with A map sensor since I've heard the Lex MAF is kinda funny on idle. should I upgrade injectors now and to what? What would I need to do to be able to have it tuned and boost every PSI I can squeeze out of the ct26? I was thinking VPC/FCD/VAFC? but I have no idea so someone please school me.
lagged
1991 1JZ
new rochelle
i run a lex meter and have no problems with idle.
15psi is about the most you are going to want to push out of your stock ct. youre gonna want a bigger turbo some day.
madseacow
360
Buda, Tx
yea, but what about my fuel cut and air fuel and what size injectors if I'm skipping the AFM and going something like e-manage? or should I get afm on top of something like e-manage? not really sure what the AFM does just that everyone says it's good with injectors. I figure either it's bigger or has a different map. Either way, I'd rather go with something different.
