Need coil pack harness wiring help
csr ma71
rooftop sniper
Apr 2, 2005
254
bay area
www.angelfire.com
I need the colors of the wires of the coil pack harness plug from both the coil pack's side and the engine's side. I was hardwiring them up because one was loose and now when the engine's started, there's a miss at idle. Just want to double check I didn't cross any wires. Thanks
csr ma71
rooftop sniper
Apr 2, 2005
254
bay area
www.angelfire.com
So I ended up changing spark plugs. The first 3 had some oil on it, but all of them were in a regular shade of black for 3,000 miles worth. Put everything back together and no more bad idle.
In hindsight, it might have just been I plugged in the #3 wire into the #5 wire and vice versa that was causing the miss.
lagged
1991 1JZ
new rochelle
i think i have both of those plugs, coil pack side and engine harness side if youd like. with nice long pig tails off of each. if youre interested.
