Need a new AFM?
JustAnotherVictim
Ok so I got the n/a engine I'm using running yesterday and I have a couple problems.
The car start up and idles kinda rough. While I let it sit and idle the rpm's begin dropping very slowly until after a few minutes of idling it dies.
I put new plugs, rotor, cap and wires on it so It's none of those. I double checked those connections today to make sure they were tight. Set the timing at 10 btdc and put some fuel in the car.
I get no codes except for a 43 which is the starter, but that doesn't matter since I have a manual start switch. I drove the car about 100 yards and came back. The car bogs when I hit the pedal and it gets a small backfire of white smoke when I take it over 3k. I'm about to go check the tps but I don't think that's the problem.
The only other possibility I was thinking was maybe a vacuum leak but I have found nothing so far.
Any thoughts?
8,894
Somebody may have done the GE airflow meter mod with it. Loosening the tension on the spring will let it open more with less air, making you rich.
8,894
If the seal on the top cover is broke, then somebody has been in there. Not to scare you either but those were like $700 new. I don't know how much now. I'm not saying you need one either.
JustAnotherVictim
Ok well I feel like a noob now but it ended up being I had spark plug wires #2 and #4 swapped.
After that it ran like a champ. I could have sworn I did those all one at a time but I dunno.
That was my problem. I think I hooked them up at night so maybe I misread the order. All good now though.
Fuzz420
Are U Here 2 take My Baby
way to get it together,n00b
