Need a little advice
NoLimitslja
61
Central FL.
What is the best way to replace the gasket on the turbo oil line I'm guessing I have to take the turbo off but if it can be done without having to do that I will take any advice I can get lol
Sent from my DROIDX using Tapatalk
theprodigy79
Irish Cream
Mar 5, 2007
221
Centreville, VA
I'm guessing you have to take the turbo off but I'm not sure I did it during a rebuild but maybe someone else on here could better answer your question either way you should always remember that punctuation is your friend lol
NoLimitslja
61
Central FL.
Punctuation is a pain in the ass on my droid. I apologize though. And I'm certain because its making from where that goes into the block like probably a wrist an hour if I were to let it run that long.
CyFi6
Aliens.
Oct 11, 2007
2,972
Phoenix
www.google.com
Dont even try replacing it with the turbo on. I am assuming you are talking about the gasket between the oil lines and the turbo, not the block. Pull the turbo and use an OEM gasket, I always put a very very thin coating of Right Stuff gasket maker on both sides of the gasket and torque to specs, and I have never had a leak.
NoLimitslja
61
Central FL.
no its not leaking from the turbo just from the block can that be done with the turbo on? I'm guessing not since its a hard pipe that carries the oil.
