So I have decided that I am going to swap a 1JZ-GTE VVT-i into my 91 Supra after my 7M-GTE blew a freeze plug. After a lot of research I've decided the 1JZ VVT-i is the best motor for what I want out of my car.
Now my question is what should I look for when buying this motor in regards to my car and what one would be "easiest" to wire (I know it won't be easy, but which ECU has the most wiring information). I have researched this; however I've found the information to be scattered all over and some contradictory. I know NOT to buy one with ETCS-i and all the ones I've found for sale are front sump, but I already have a line for a rear sump pan from a friend if I need it.
