i want to go na-t but have no clue where to get gte electronics. can i use stock na electronics if i tune with the greddy emanage? also has anyone ever twincharged there car? (superchager and turbo)
The 7m has been twin charged yes. You can use the ge electronics but need to retard ignition timing via the distributor. I would only run 5 psi with the ge electronics, high compression and 91 or 93 octane gas otherwise there will be detonation.
