Na-T Numbers
NA86.5
NA-T Complete Yo
Jan 20, 2006
459
Alice Tx
I was wondering if anyone has a dyno sheet on what numbers they made when they did a NA-T. And Iam talking about leaving the stock 7m in there just adding the turbo stuff and running a SAFCII or MaftPro? Seeing that Iam going through this process as we speak. I cant wait to be boosting Wooooo
::w00t::
s383mmber1
3,614
Somers New York
::w00t::
Im with you on this one! I just got up from the garage! Ive seen stock 7mge with a ct-26 on 10 PSI running right around 265-75.
Are you keeping the stock headgasket? Cause thats really going to resrict your power goals and upping the boost.
NA-T Ftw.:biglaugh:
NA86.5
NA-T Complete Yo
Jan 20, 2006
459
Alice Tx
Yes Iam going to keep this head gasket due to the fact that I just relaced it about three years ago. I hoping I can boost at least to 15-17psi max and the least 10psi I hope I can get it up there. I know it will get up there but it might blow up.
s383mmber1
3,614
Somers New York
15 PSI!?!?! Damn!
Good luck.
I think youll be more than happy with 8 :icon_bigg
Ma70.Ent
1,871
NJ
s383mmber1 said:
15 PSI!?!?! Damn!
Good luck.
My brother is running around 14 PSI on stock HG (torqued down though, which i'm sure the TC did) with 8 btdc timing. I don't think 15 is a problem.
pimptrizkit
thread killer
Dec 22, 2005
1,572
vancouver Wa
one three years ago!
thats not bad.. ive done 3 this year!
i replaced the one on the jdm i bought, blew it, then put on a mhg, fired it, and im now running another mhg, i fried it due to slightly warped block, and improperly prepping the block.
and 15-17psi on an na-t your asking for alot of problems.. exspecialy with an oem style head gasket.
i would reccomend atleast block prep& head prep 25ra, and arp's. it's money well spent!
ForcedTorque
Join the 92 Owners Group
Jul 11, 2005
6,099
I bet you won't get 3 years out of 15PSI on a stock head gasket. You're gonna get addicted to the boost. I couldn't imagine having an N/A, then finally getting to boost. Good luck with the project tho.
