NA lsd
JDM 1JZ
I hate Tires
Aug 31, 2005
301
Cherry Hill, New Jersey
does the 4:30 na lsd use the same axles as any other lsd supra rear? anything that needs to be changed? and what do i do about throwing the speedo off, not that i care to much
8,894
You might consider caring a bit more if you ever sell the car. You will have many more miles indicated than you really have. Depending on how long you drive of course. Same axles.
You will need GE driven gear and drive gear.
tomjan87
121
Madison, WI
ok, first yes everything is the same, just swap them out.
2nd, the speedo will be off, if you have a 87-88 then it will be off by 10 percent so 5 mph at 50 and 89-92 it will be off by 14% 7mph at 50(dont quote me on this, i think its right.)
gas mileage is also not the greatest. I put a 3.91 in mine instead of a 4.30 cause at 3k in 5ht i think it did about 60 mph ish.
your choice.
7M-GTE
ROCK$T@R
Apr 2, 2005
535
KC
I have the NA LSD in my car right now... it throws the speedo off by about 11mph by 70 or so... and it sux for gas and highway driving... it still uses the same axles I have the r154 so if I got the speedo gear from toyota I could match the tranny with the rear end I just havent gotten around to it... this rear end is good for lower hp cars IMO unless you have some slicks... c\ with my stgIII clutch and stock turbo 550's and maft I was chirpin 3rd... after the rest of my parts go on I think I'll be looking for traction forever... just my two cents on the rear end... I wish I had a 3:91 or the 3:73...
