na intake vs turbo intake
7MGTEsup
Formerly 'Down but not out'
Jun 14, 2005
614
England
eviltwins said:
i was just curious. can i use a na intake mani on a turbo engine or is there a difference? thx
I think the N/A has a veriable intake track and the throttle body might be smaller.
shaeff
Kurt is FTMFW x2!!!!
11
Around
the gains arent worth all the extra work. in fact, if i remember correctly, there are no gains, as the AICS doesnt function properly under positive manifold pressure. :)
-shaef
tubbie
Yes, powerful Jedi....
Apr 4, 2005
821
Hoschton, GA
If you have an na intake, just keep it. Not worth it to change to turbo intake. Same thing if you have a turbo intake.....
But....... :rofl:
Me and a friend dynoed both our supras on the same day. We both have the same exact mods, except I have the NA intake, and he had an eBay intercooler, dynoed about 5 minutes apart. I dynoes 368 and he dynoed 356, both at 18psi...... Just food for thought...
Godspeed
88 supra turbo 5spd
May 13, 2005
1,119
Asheville n.c.
i was just wondering because when i get my new supra i need an intake mani. cuz he said he sold the ffim and i have an na intake mani. but didnt know if i could use it or not.
Shawndude
Van BC
They are different, and not worth swapping unless you're after the last ounce of power. If you use it on a turbo car it gets in the way of the coil packs.
The active variable tunning of the N/A manifold will work even in turbo application, but the effective range will be pushed lower the more boost you use. It may work wonders to wake up a lazy big turboed car, but otherwise just stick with what you got.
