na compression, max boost
hottscennessey
DONT BE A BITCH!
Jun 3, 2005
3,137
Richmond, VA
Methanol and full timing control (standalone) and you should be able to run a decent ammount.
As per an actual PSI number, we need more info on the setup (turbo size etc.).
need new tires
rubber slinger
Nov 10, 2005
173
Dayton,Ohio
on a stock ct 11-12psi is the max "safe" amount on stock n/a compression with a mhg. a local guy ran up to 18-21 before BOOM. meth and retarded timming are good things tho.
-shane
