NA Cams
88YotaTurbo
658
Wolcott, Ct.
I was surfing on 7mpower.com and notice some guys running the n/a cams. I have a n/a parts car with a new head. what the deal with running n/a cams with the turbo? how can I use this to my advantage?
jdub
Feb 10, 2006
10,730
Valley of the Sun
Do a search...there's a ton of info already here.
88YotaTurbo
658
Wolcott, Ct.
searched arround and found alot. I want to swap them since I have a brand new head laying arround and brand new cams in it. I jsut want to know the timing to set them at. Same as stock or no? I believe stock is 12 btdc??? or 15 i forget.
jdub
Feb 10, 2006
10,730
Valley of the Sun
It's in the TRSM...here it is on-line:
http://www.cygnusx1.net/supra/techtips.html
It's the same as stock - 10 deg BTDC w/ terminals E1 & TE1 jumpered on the test block.
shaeff
Kurt is FTMFW x2!!!!
10
Around
personally, i don't think it's worth the trouble at all. it only moves the powerband around, and if you're going for around 400hp, the N/A cam will start to stifle the motor. less lift, more duration. ;)
-shaeff
8,894
Lift is different. I don't know about duration, it isn't listed in the repair manual. My 91 manual lists intake GE lift as 38.16mm and GTE lift as 38.35mm. Exhaust has the same lift.
Which looks like a reprint from my old 88 manual. But I know they have different part numbers at one point. Like in 89, when the car gets the "Cressida" cam profile.
shaeff
10
Around
jake, i read something that i *think* jeff lange posted some time ago. i can't find it now, but i'll keep looking. it stated the info that nick just posted, as well as the duration of the cams. i don't remember the numbers, but i remember the reading that the valves would be staying open longer with the N/A cams, (duration).
perhaps my memory has failed me? it wouldn't be the first time, i suppose. i'll keep digging.
-shaeff
