NA cams anyone?
MPF_Supra
Wisconsin
so i've tryed and tryed and tryed. nothing popped up about the NA cams on 7mgte motors.
i've heard both side of the stories. now for the guys who actually has experience with NA cams tell me MORE PLEASE!!!!
are they a waste of time putting in or is it actually worth the time to.
i hear there good and i hear there bad..what's the real scoop?
thanks
-mPf
IHI-RHC7
"The Boss"
Oregon
Here's the duration based on the Toyota literature comparing and contrasting the 7M to the 2J
Exhaust NA 236
GTE 236
Intake NA 226
GTE 236
Utilizing Jeff's info on Lift,
There are 5 cam part numbers for the Supra, take from this message whatever you want, heh:
Intake:
13501-42020 - 86-87 N/A Intake Cam (38.36mm Lift (I think, I'm not 100% sure on that, can someone with an 87 TSRM check that for me?))
13501-42030 - 88-92 N/A Intake Cam (38.16mm Lift)
13501-42010 - Turbo Intake Cam (38.35mm Lift)
Exhaust:
13502-42020 - 86-87 N/A Exhaust Cam (38.36mm Lift)
13502-42010 - 88-92 N/A Exhaust Cam & Turbo Exhaust Cam (38.35mm Lift)
I have no duration information though.
From this I gather, Turbo cams are the same for all years. 38.35mm lift, 236 deg duration
Provided Toyota didn't muck around with duration for the different NA cams, then you have three options.
1) 86-87 NA Intake cam 38.36 mm lift (maybe) and 226 deg duration.
2) 88-92 NA Intake cam, 38.16 mm lift, 226 deg duration
3) 86-87 NA Exhaust cam 38.36mm lift, 236 deg duration
The only one that has better numbers than your stock turbo cams is the 86-87 na exhaust cam. You gain one hundredth of a milimeter of lift....
Not worth it IMHO
-Jake
spipedong
Level 2 Rythym Rogue
Apr 2, 2005
404
Eugene, OR
I've got the N/A cams and I can't say there's any proof either way. I didn't have a before comparison at all.
woot for .01mm lift.
