Correct, apart from that the N/A intake cam has shorter duration than the turbo (and tiny bit less lift). Unless you're after better gas mileage out of your car, I wouldn't bother with it again.Squid699 said:my understanding is that the exhaust cam is the same, and the intake for the NA has a slightly longer duration. For moderate or low HP applications this provides a small gain at the lower end, but doesn't do anything, and possibly hinders performance in higher HP applications.
Jeff Lange said:I have no duration information though.
