N/A to 7M-GTE swap
88supraFAST1
7M WHAT
Feb 8, 2006
421
Battle Ground, Wa
OK so im getting a GTE for my 88 N/A i was just wondering if the harnesses are diffrent between the NA and the turbo im sure they are i just want to clarifi that. another thing is there any diffrents from the na head and the turbo head, are the parts from each heads inerchangeable? I.E. Like the cams valves and so on. thank you for the help.
Dirgle
Conjurer of Boost
Pauma Valley, CA
Yes, the harnesses are very different. N/A has a distributor, 1 knock sensor, ect. The turbo has the Coil pack, CPS, 2 knock sensors, ect.
The heads are the same except for the Intake cams and the valve covers.
Here is a good site to find out exactly what parts are needed to do the swap correctly.
http://www.4cefed.com/conversion.html
