N/A-T oil return question !!!!
MKIIIChucky
101
south jerzy
On my block it looks like I have a block off plate where the oil ruturn is on the turbo blocks ... Am i able to use that as a oil return or do i have to go to the oil pan ??? thanks , MKIIIChuckY
JT87NA
SLC, UT
IJ. said:
You can use the stock Cooler return in the side of the pan or you can drill the block in the GTE location.
Yup, I would recommend welding a -10 an bung onto the stock oil cooler return, the original hole is 12x 1.25 mm kinda small, it will work...Maybe.
MKIIIChucky
101
south jerzy
i think ima stick with the orignal plan n just weld a bung into the oilpan , its seems the easiest + i wanna reseal the oilpan & put a new seal on my oilpump!!!
MKIIIChucky
101
south jerzy
iceberg319 said:
im praying that itll work, if not ill jus drill to make it bigger
i heard u can use this and do it without taking off the pan
http://store.autotoolexpress.com/blr11128-3.html
drip and tap for the size
if u ask me i think it would be better to pull the pan off couse u can reseal the pan & put a new seal on the oilpump if needed, + how much that thing coast u can have a bung welded in for that much !!!
MKIIIChucky
101
south jerzy
IJ. said:
Oilpump seal?
o-ring on strainer n gasket on oilpump outlet pipe, got atleast 200k miles on it soo i wanna atleast get all new little stuff since it gonna be off for like 2 week .... if its in good condition
