N/A Dyno Numbers
Fuzz420
Are U Here 2 take My Baby
This was the first time on the dyno ever, so i didnt know what to expect. I was hoping for about 150hp. I didnt quite make it there but im happy.
141hp and 154ft/lbs isnt too bad in my book
Click to enlarge:
For reference my mods FIPK, 2 3/4 inch custom catback,1 aluminum d/s
From here the only way to go is up
GotToyota?
Dedicated Member
Apr 6, 2005
1,639
Texas Motor Speedway
Wow, way less then I expected. How many miles are on your car? Honestly, we had about 200hp from the factory, which was about 188hp. I wonder how our cars lose that much power over time.
-Matt
Fuzz420
-Matt
the motor is one of those jdm deals with 40-60k on them, ive put 30 on it since ive had for the last year and a half.So your guess is as good as mine
BorHor said:
We need more N/A's to dyno. Then we can see what the avg is.
Exactly, thats why i posted this, n/a sheets seem hard to find
BorHor
2JZ-GZE
Jan 10, 2006
6,181
San Jose, CA
NVM wrong numbers. Here is his Dyno sheet. His car is stockish also.
*edit*: WOW you 2 have almost the same numbers.
s383mmber1
3,614
Somers New York
Fuzz420 said:
I have also been informed by the "higher powers that be" that my ACIS may not be activating properly, as a in to comparison to kyles sheet. 4200 should be the magic number
You read my mind! I was thinking that when looking at your sheet. 4200 Should be a real magic number.
V-tec y0
Ma70.Ent
1,871
NJ
s383mmber1 said:
Traitor? :naughty:
Nah, I don't care about that. I just thought you shouldn't mention turbos in the N/A forum + I wanted to use that smiley. :D
Ma70.Ent
1,871
NJ
s383mmber1 said:
turbo turbo turbo turbo turbo turbo turbo turbo turbo turbo
:momaru:
:nono: :nono: :nono: :nono: :nono: :nono: :nono: :nono:
I need more posts. But that's enough. :)
Tanya
1,851
Naples, FL
Ever do a compression check on that engine Fuzz?
For a 7M with an alleged 70-90k miles on it, 140 seems pretty low to me, especially with the exhaust. (unless you ran on a mustang dyno, which I double checked to make sure you didn't)
My 5M put down 144whp and 143wtq with just a 2.25" exhaust and the engine was pulled from a car with 240,000 miles :aigo:
I know all engines wear differently (especially if they had a previous asshat owner) but I would definitely look into why you're missing a few ponies there.
