right now im not sure whats up with my car(89 cressida). the car idles perfect and im not throwing any codes but once i hit the gas pedal like a 1/4 of the way it just want to shut off. im thinking it might be the tps (waiting on getting a volt meter from a friend to see if its set right or not) i also have friend that says i should put a walbro 255 (i will sooner or later) in it because i might be running too lean (i have the stock cressida pump right now and im about ot do the 12volt mod). i figured i would post to if anyone else had any ideas on what it could be. im not sure if im over looking something and it just something dumb wrong with it.
heres a little back round on the set up
7mgte ecu
mk3 440cc injectors
7mgte coils
7mgte cps
7mgte afm
7mgte sensors (knock, coolant, oil, ect)
20mm(?) spark plug wires (i cant remember what size my buddy said they were)
egr removed
removed actuator for butterfly in the intake plenum (always closed now)
i cant remember if thats everything because im half asleep right now
video
http://www.youtube.com/watch?v=ifYyjZMWm40
7mgte ecu
mk3 440cc injectors
7mgte coils
7mgte cps
7mgte afm
egr removed
video
