mystery box, a little help please. pict inside...solved it is lojac
what would you do with it
  • leave it be
    Votes: 3 7.1%
  • remove it, then baseball it!
    Votes: 13 31.0%
  • figure out if it is useful, then decide its fate
    Votes: 26 61.9%
  • Total voters
fixitman04
fixer of all things !!
Sep 18, 2008
787
north dakota
im currently recovering my seats and inserts, and i found a mystery box in my drivers rear panel. it is wired into my harness and has a antenna like wire coming out of it taped to the wheelwell in a loop. it is wired witha pinch connector so i know toyota didn't put it there. the orange sticker says "lead acid sealed battery":1zhelp:
it looks like it has been ther a while, and im in good standing with the woman....so i know it isnt explosive:icon_surp:sarcasm:
any ideas?
IwantMKIII
WVU MAEngineering
Jun 12, 2007
2,477
Perkasie, PA
you should see all the fun wiring stuff in my car i just found. Looks like enough power and equipment to listen in on a spy sattelite.
Zumtizzle
Can't Wait to Be King.
Oct 21, 2006
2,825
Sac-Town, NorCal
there should be a FCC on it somewhere.
i'm 99% sure it's a lo-jack unit.
Lojack hides these things in the most odd of places from my experience under the steering wheel, behind the glove box..etc.
All they need is 12 Volts.
fixitman04
Sep 18, 2008
787
north dakota
great info, so i can ditch it then.
orig owner musta had it done then, i have no use for it and no idea how to test it or register it with lo-jac. wonder what wire they tapped for power? red with a silver stripe...on a 91 turbo.......anybody?
Zumtizzle
Oct 21, 2006
2,825
Sac-Town, NorCal
How do I know if my LoJack is working?
Your LoJack is tested and certified at the time of installation. We then recommend an inspection of your LoJack every two years. Inspections cost $79* and can be arranged by calling 1-800-4-LOJACK (1-800-456-5225).
*Pricing is subject to change without notice.
back to top
What do I do if I believe my LoJack requires service?
Call us at 1-800-4-LOJACK (1-800-456-5225) to schedule an inspection of your LoJack or to talk to a Customer Service Representative who can answer any questions you may have. For faster assistance, please make sure you have your Vehicle Identification Number (VIN) at the time of the call. Your VIN number is located on your LoJack I.D. card or your vehicle registration.
back to top
Does my car need to be running for LoJack to work?
No. The LoJack Unit constantly draws a very small amount of power from your vehicle's battery. Should your battery be disconnected, LoJack's backup battery will provide power.
More info for you.
lojacks do not look like that. at least the 2 generations i have installed. early warning or not.
what is power and ground hooked up too? constant 12v? where does the antenna go?
fixitman04
Sep 18, 2008
787
north dakota
ground hooks to the body at the mtng screw, the antenna goes up the wheelwell to a cardboard pad and then makes a loop back to the pad. havent tested if it is switched or constant pwr. will do that later today.
jetjock
creepy-ass cracka
Jul 11, 2005
9,439
Interesting. From it's color the battery is an older model PowerSonic. I'm guessing a PS-1270. That size battery (why would stereo boosting need battery back up?) and the type of antenna indicate a transmitter. Could be an old DYI surveillance tracker. It'd help to know the cable/antenna dimensions so a stab at the frequency can be made. A pic of the guts would tell a lot too...
crisp
existentialincrementalist
May 25, 2007
1,785
Ohio
Very interesting! ...makes you wonder if it was security, or a suspicious spouse or parent? (tracking device...)
Hopefully NOT a "Road Warrior - a.k.a.: Mad Max" booby trap!:biglaugh:
G/L, and post if you find out definitively! I'd be curious to know for sure for future reference.
-crisp
chrgd89
26
Leander TX
looks like a old school tracking device that used car dealers use. No payment, they track the car, with an extra set of keys and drive it away.
zambini
464
Detroit, MI
that's kinda disturbing, kinda cool as well... id have that thing out of my car though and that is for sure! haha plus once its out you can inspect it further..
fixitman04
Sep 18, 2008
787
north dakota
im very curios as to what this is, im gonna remove it and see if the car still runs. i dont know. it is on a switched circuit. im gonna say the first guess is correct. it is definatly a transmitter and it is battery backed up.
there is a fcc ident on the back
did a quick batt test and it is dead the antenna is rg 58 coax. it has a transmitter style board on the end and a modulator daspot set about 4 inches from the box. it is 4ft overall length
more picts
antenna
modulator
any way thanks for the help guys, its gonna get removed for now till i figure out exactly what brand it is. i should be able to do a fcc id search, if i can find the right person/dept to talk to at the fcc
