my trunk is leaking water
jlaghetto
Raynham, MA
does anyone have any ideas where my trunk could be leaking???....everytime it rains there is a big puddle at the bottom of my trunk....the carpet is never wet.....it seems that it just somehow gets to the bottom....
foreverpsycotic
Back in the game!
Jul 16, 2006
3,171
12
ATL
Welcome to owning a supra, pick up some taillight seals and rear window seals, and remember to drain the water you have in the back now or risk the spare tire well becoming an easier way to change your fuel pump.
BorHor
2JZ-GZE
Jan 10, 2006
6,181
San Jose, CA
Ds650rida said:
i have a problem with water in the panel under the spoiler, whenever i open the hatch, it runs out the corners all over everything.
Probably the lower window trim. It can also be the spoiler holes though.
Doward
4,245
Alachua, FL
GeneStarWindGSW said:
You can also get water in from your wing by the bolts that hold it down aren't tight enough and water can seep down, but not much.
Usually all it will do is rust the inside part of where your wing is at.
*all* it will do? That's the damn reason I had to replace my hatch :3d_frown:
super.secret.supra.club
1,304
San Diego, CA
I had both the wiper arm and hatch area leaking to rust into my car from the previous owner. It kinda sat around for a few years before I picked it up so the rust ended up eating a grapefruit sized hole through the spare wheel well of the car. I would've ended up using this "kickass!" rust converter stuff my paint guy referred to me but I ended up removing the spare wheel option entirely. Replacing all the rubber seals in the rear of the car wasn't cheap going through Toyota even with a discount, but I'll be relieved when it starts raining. Well, that's if California ever gets rain.
