The adjustment lever inside adjusts by percentage. So if you're off by 10% (ie you do 30 it says 33, you do 60 it says 66) then you can use the lever. If it's always off by 5, pull off the needle and put it back on where it needs to be.... sad that it has to be said, but it has come up before.
