my problem...
thesandymancan
a.k.a: mittens
Mar 7, 2006
233
boise, idaho
i can't figure out how to bolt my oil return line on. is there a proper method that is fairly simple. i've tried to bolt it onto the block while it was attatched to the turbo, i cant get it tight enough. someone told me to bolt the line to the block first, then attatch the turbo... but i don't see how it's possible.
:1zhelp:
Joel W.
Just A Jedi
Nov 7, 2005
1,561
Washington
I bolt both lines to the turbo first, with the turbo loose from the manifold, I make sure the feed line goes over the studs on the block. Then I get the return line bango bolt started while you can still move the turbo around a bit. Once that is started, I tighten everything up.
thesandymancan
a.k.a: mittens
Mar 7, 2006
233
boise, idaho
the problem is getting the bolts tight on the hose with two bolts (the feed line?). i can get everything where it needs to be but i cant tighten thoes bolts and it's the only thing keeping me from driving my supra! super frustrating.
Joel W.
Just A Jedi
Nov 7, 2005
1,561
Washington
I used a socket and a 6 inch extention I think maybe a couple of shorter extensions with a deep socket?. I can't recall now. Get the socket/extensions on the nuts and then put your wratchet on the end of it. Not much help here, sorry. Most of it was by brail for me.
Insidious Surmiser
Formerly 89jdm7m
May 12, 2006
2,172
Oceanfront
soft lines FTW!!!! i musta spent liek half a day total if you compile the amount of time it took me to put st-26's on 7m's... next time, i'm gonna make my own soft lines, seriously
thesandymancan
a.k.a: mittens
Mar 7, 2006
233
boise, idaho
that sounds good but how would you attatch them?
