my heater control valve broke..
theKnifeArtist
Fire on High!
Apr 6, 2006
2,332
North Jersey
so this is the latest culprit for my latest coolant leak.
i was commin home from school and the end cracked on me and pissed coolant everywhere...
the other side is broken cuz of when i was taking off the bottom hose from it. i need to get a new heater control valve to fix it by next friday... how long would it take to ship from one of you guys here? fucking toyota wants to charge me 187 for the fucking thing. thats rediculous. that really pissed me off..i have a situation pending where im supposed to get it from someone in the area, but i dont know if that'll work out..
djordan97
199
Kennewick WA
yes you can bypass it just make sure you plug the vac line heading to it. if you do bypass it then it'll act just like a normal car in that you will always have coolant flowing through your heater core. I bypassed mine because I didn't feel like paying for a new vsv.
theKnifeArtist
Fire on High!
Apr 6, 2006
2,332
North Jersey
what triggers this valve to open?
and what vacuum line do i plug up.
im gonna go do all the bolting right now and ill probably be back in a bit if i dont figure something out
djordan97
199
Kennewick WA
there is a sensor that opens a vac valve hooked to the assembly that recieves a signal when the thermostat inside the car calls for heat. then the vavle opens and allows warm engine coolant to flow through the heater core to provied heat in the interior. the vac line would be the little black plastic tube that runs along the firewall accrossed the car.
jdub
Feb 10, 2006
10,730
Valley of the Sun
If you got an old accordian hose laying around, take one of the small metal hose fittings out of it and use it as a splice for between the hoses. Just clamp both ends tight. You do know this will give you full time heat.
shaeff
Kurt is FTMFW x2!!!!
10
Around
i just got some 5/8" heater hose from the autoparts store and got rid of all that. i didn't want an extra joint that could possibly leak.
-shaeff
supra90turbo
shaeff is FTMFW!
32
MA, 01440
In all actuality, it's always open.
The only time the VSV triggers it to move, is when the AC is on.
It closes the valve, stopping the flow of hot coolant through the heater core so you don't reheat the cooled air coming from the evap core.
jdub
Feb 10, 2006
10,730
Valley of the Sun
-shaeff
Yeah...that would be better. I was just thinking of a temporary fix until he could get a new HCV.
theKnifeArtist
Fire on High!
Apr 6, 2006
2,332
North Jersey
yeah i put them together with uh...i forget what the term is...pretty much a 3/4 plastic tube to do exactly that. ill get a new heater control valve later on, this'll work for now. thanks for the help guys.
