My first 7mgte build
leftynridge
401
dayton, ohio
I'm trying to get in idea if my current set up will achieve 400-450hp and at what psi. If not what next? I have not got my car tuned yet so just trying to figure out what to expect. This is my current set up.
-60-1 ct turbo
-spearco replica ic
-map-ecu
-rc 550cc injectors
-walbro fuel pump
-3in. exhaust
-aero fpr
-greddy type- bc
-spec stage 3 clutch
no ct will get you to 450. 400 yes but maxing it out which is not a good thing. maybe look into the sp61 bolt on turbo. will get you there easy and then some and will mate to the ct exhaust.
every thing else looks pretty good but i would add a afpr and a wideband.
leftynridge
401
dayton, ohio
I have a zeitronix wideband just can't get it to work. Worked with Zeitronix and he is puzzled to. What hp can be achieved before replacing internals SAFE HP.
leftynridge
401
dayton, ohio
I'm in the process of getting my car painted just got my body kit from shine auto today. Feel like a kid in a candy store. But should be getting it tuned in a few weeks. Will let you know.
leftynridge
401
dayton, ohio
I will start taking some pic's and posting. Will get my tax return in about a week so I will have some money to play with. By the way the guide was helpful. Thanks
Kevin
7mgte -> 7mgte swap done.
Apr 20, 2009
865
Windsor Ontario Canada
hmm why would u wanna spend all that extra money. all u want is about 400hp right?
btw hyman my bad you are right. its not a good idea to run it up that high but i am sure you can get up to 450-500 level no problem with a 60-1 ct26
a 60-1 does not provide you with that much more hp than what a 57 will do. and it does not last even lose to as long as a 57. there are vendors who used to sell the 60-1 but stopped because of its unreliability. if you max it out sure you will get above 400 but for how long? any upgraded ct starts blowing hot air around 17-18 psi and reliability just goes out the window.
if you want that kind of hp reliable get a sp61 or something similar. there are other 60-1 turbos out there that bolt up no problems that will make that but they are not ct's.
