my exhust what do u all think
87centertips
107
edmonton alberta
well as the topic says i would like u opinion on my exhust and so i don't get a bunch of dose that restriced hp i'll awnswer that now it only restrics 2 hp but i made that up by having 2.5'' pipe with no cat and a rez with a dynomax performance muffler
N
NDBoost
Guest
if anything i would of kept it looking stock, on either the far left or far right the pipes kind of flow w/ the body styling. I wouldnt do two in the center, if your going to do something like that id do either 1 on each side or two together on the left OR right.
Briskie
11
Londonderry, NH
I think I like the looks of its definitely unique. I'm pretty certain too that because of the location of the gas tank you cant do tips on the left and the right, unless you just split the pipe before the normal exit and ran it all the way across and underneath the bumper, and that would have to be pretty restrictive. Kudos on an original idea.
KeithH
Portland, OR
Definately unique. Have not seen another Supra with center tips before.
Having said that - how do you know that it only restricts your hp by 2?
Time for a trick custom rear bumper skin to tie everything together nicely.
87centertips
107
edmonton alberta
^^haha i like that ''time for a trick custom rear bumper skin to tie everything together nicley.''
as for the 2 hp i'don't really know on my car but my brothers MKII has the same exhust and thats what we guessed from his on the dyno
aye mate
Hiatus over.
Maryland
Appears to be NA so I would say (when it comes to power) a 2hp restriction from those tips is the least of your worries. It looks like a clean install. I would have chosen a different tip style though.
89MkIII
targa'd tank
WI
I like it, nice idea. I don't know if your car is ideal for it though. I think it would look a lot nicer on an 89+ and a lighter color. Bumper customization, like a cutout, would look really sweet too. Nice fabrication though!!
mkIIIman089
Ohio
Doesn't look too bad, and its origional. I don't like it though myself, I share the Corvette comment with robbo.
Suprastic
727
Manitoba
it looks good and clean. If I were you I'd make a custom rear underbody diffuser out of sheet metal. Then you'd be looking like a leMans car. I saw a guy with a Jetta in PAS mag that did center tips and under diffuser and it was coolest and cleanest I have ever seen. You've got a great start though.
MKIIINA
Destroyer of Turbos
Plano, TX
not bad at all. only worry i have would be the proximity of the hot exhaust to the gas tank. kudos for something new
