My dyno run at the Indy meet
I don't get it.......where's all the black and white smoke and green liquids that's suppose to spit out of your exhaust on the dyno..............:biglaugh:
Car sounds great. What were the numbers?
suprafanatic
1,607
Greenwood, IN
lol, it was putting out alot of smoke, for some reason you cant see it in the video.. i was running open down pipe so thats prolly why. you can see it from the side of the car, as it was running very rich. on the dyno i was only running 7psi and made 284hp and 321ft. lbs of torque.
suprafanatic
1,607
Greenwood, IN
no i didnt, for some reason my car was having some problems, it wouldnt hold boost over 7 pounds, i normaly run about 15pounds.. so if it was running right at 15 pounds it should have been well into the 300s i would hope.
easily into the mid 300's I would think. My 1jz makes 390 @ 12psi, but that's with the gt35.
Boost Lee
Bee Doo Bee Doo Bee Doo
2,750
Indianapolis, IN
I've got his video from Chicago.
He did I believe 243rwhp on a failing stock CT and open downpipe. Everything else was stock.
It was [obviously] at Sound Performance and they use Dyno Dynamics as well as E-MOTOR's (Where he dynoed in the video posted above).
Good job, Nate. :) Now get 'er tuned with what you've got, then time for more fuel. :)
Jeff
