my crap 2jzge
sahirb
Oman
One thing, can i setup a turbo on this engine and get more than 8 psi, i mean all the turbo setup im comin at r 8 psi setups, can it go higher without crashing the engine?
second, which manual tranny fits on this car?, please help me guyz, my auto tranny is dead alrdy i need a change!!
supradan22
NA->TER
May 20, 2005
915
ORLANDO FL
Im guessing you have a sc300? well anyway yes you can setup a turbo on the motor if you build it right. The 2jzgte pistions fit and there lower compressed and the sky is the limit from there as long as you have enough fuel to back it up. For trannys the R154(turbo MKIII tranny) and the Gettrag(turbo MKIV tranny) fit but you need the 1jz bellhousing for the r154 and a custom drive shaft same with the gettrag but you will need the proper bellhousing for that one to.
sahirb
Oman
I have a '93 Mark II, which is better known as Chaser, with a 2JZ-GE, I actually imported it from Japan to where I live in the Middle East. I liked the car because of its aero dynamics and got it, I had no knowledge that it didn't have the 1JZ-GTE. Where I live not many people are car enthusiasts and when you would like to do an upgrade for the car and ask the technicians, they just tell you to buy a Skyline or a car with power from before with a turbo engine.
Can you guys also give me links on where to buy the tranny, I hate the automatic.
Anyways, my ride looked like this 6 months ago http://www.cardomain.com/ride/707531
