my clutch problem
black91turbo
Formerly black87turbo
Apr 27, 2006
1,064
Jacksonville, FL
hey guys, i have a problem. My clutch used to stick to the floor, (tried bleedin it but I was swingin) so i replaced both the master and the slave cylinders which i got at toyota. Now I'm tryin to bleed the bitch again but I can't get it to come up more than half way after I press the pedal down. I checked for leaks in the lines but everything seems good. Neither cylinder is leaking or anything.........they're brand new. I dont have a clue........Any suggestions??? Thanks in advance :1zhelp:
Joel W.
Just A Jedi
Nov 7, 2005
1,561
Washington
I agree with Nick, I had a bitch of a time trying to bleed mine by myself.
Even when I thought I had all the air out, 6 months later there was still air in the system that effected the pedal height..
black91turbo
Apr 27, 2006
1,064
Jacksonville, FL
Hey thanks guys, I tried bleedin the bitch again ( it took me a bit longer) and it actually works now. Therefore you guys were obvioulsy right.........thanks again
