my Caster is off... control arm problem?
Oni
12
Los Angeles
i was just doing my alignment when i saw that one control arm was able to go 7.5 degrees on the caster (stock caster for mkiii), and my other control arm was only able to move to 4.5 degrees. could this be subframe damage or a bent control arm? i also noticed that the bar just under the oil pan was slightly bent. the control arm looks fine but still questionable.. 3 degrees off is bad and turns kinda hard on the freeway... toe and camber is fine btw.
~Adrian M.
