This is deja vu all over again for me. I had all of these symptoms with my son's '89 N/A 5-speed. I believe you have two separate problems, as I did.
thechori said:
coolant is leaking ONLY from the overflow tank, but the car is running perfectly. BUT.. in the overflow, the tank is pretty dirty, and it is contaminating the coolant, but i don't know how to find the leak
Coolant being pushed out the overflow and an oily film on top of the coolant in the overflow tank after it sits overnight, strongly suggests a BHG to me. I had this and found the most conclusive way to check it was to pressurize each cylinder (80 psi) for 5 minutes and look for air bubbles in the radiator. Note; my BHG was a very small leak (preliminary to a big one) so I was able to fix it with a re-torque. I would address this problem first when you are changing plugs. See my posts in this thread:
http://www.supramania.com/forums/showthread.php?t=16296&page=3
thechori said:
well, i went today to get the car inspected and the guy said it was running really rich, wasn't near passing.. definitely explains why i've been getting pretty crappy mpg (around 12-14)
Been there, done that. My emissions were 10 times the maximum limits. This was a long row to hoe for me. Turned out to be the ECU but you have to eliminate a whole bunch of stuff first unless you happen to have access to a spare for testing. And besides you might find another cause along the way. Good advice from
CRE and
cypher02xd on starting with the O2 sensor. Note; if you finally decide it is the ECU get a used one (new = $hundreds).
I used the “Inspection of Oxygen Sensor” routine on page FI-118 of the TSRM to tell me what was going on and to tell when it was fixed (thats important). I also connected an A/F Ratio gauge to the diagnostic block (as well as the voltmeter) to show me a picture of what was happening. Here is the link to the TSRM (site seems to be down right now):
http://www.cygnusx1.net/supra/library/TSRM/index.html
Also, my thread on this problem:
http://www.supramania.com/forums/showthread.php?t=14266
thechori said:
the car has created a pretty huge buildup at the end of the exhaust pipe that looks something like really dark grinded coal or something
I too had a lot of black crud in the exhaust system and the plugs were very black. I believe it was a function of running so grossly rich. The other bad news is that once you get your mixture corrected, you may find the Cat has been damaged from all that rich mixture. Sorry to be the messenger on this one.
Hope this helps. Good Luck.
