My car seems to be running and Capacitors in the ECU
bobiseverywhere
bobb'n for money
Montreal
www.bobiseverywhere.com
Here is the Video
(Right Click Save As)
http://www.bobiseverywhere.com/images/supramania/1jzbuild/MOV03329.avi (27.8MB)
And i forgot to mention that The guy that worked on my ECU had to replace a ton of Capacitors Just out of need and i had the rest done out of preventative maintenance
There was a total of aprox two dozen changed possibly more can't really remember.
here are the different types of Capacitors that are in there
There are basically three types of capacitors here.
1 Mylar, These are the metal can type = These give the highest fail
rate. These are polarity sensitive
2 Ceramic. These are the little ones that are square or round flat
type. these give the middle fail rate
3 Tantalum. Those are the ones that look like a tear drop and have a
gold or silver dot on the top. gold=5% tol. silevr = 10% tol. These only fail if you see they have exploded. these are also polarity sensitive
Tantalum capacitors are sensitive to low temperature. In -55C they will explode just by turning on the engine key. That is why they are normally made to +55C and -75C.
