My build ...
slacker
master mould maker
Sep 24, 2006
123
BC , Canada
www.toyotafiberglass.com
so look what I got back earlier last week .
time to get going on the build ... :)
rings are Altrom ... water pump is Nissan :-X ... rest is OE.
first coat of primer ...
What? No purple block? How are you going to make 667rwhp without a purple block? You don't know a dang thing about building a 7m.................;)
You may not have been around enough to know what I'm talking about. Good luck with your build though...............lol
Someone on here said that Kwnate's block was Barney purple, but he swears it's blue. Anyways he laid down 667rwhp and about two thousand pounds of torque. I sometimes exaggerate about his torque, but it was alot.............lol
Slacker, it's looking very good. I hope you have no problems and it goes very smoothly..........:bowdown:
CPT Furious
Now MAJ FURY!
KDOV
That looks great! At first, I was wondering why your water pump was on the right...then I slapped myself...:)
slacker
master mould maker
Sep 24, 2006
123
BC , Canada
so a little bit more today ..
got the pan on ... of course it came with a cork gasket that i'll never use .
and some of the accessories ..
MLS head gasket in place , and new ARP head studs .
and the head goes on , and torqued to 80FT lbs
back cover and set the valve covers on for effect .
and almost done ...
so thats it for now ... I had to order the turbo oil pipe gaskets .
slacker
master mould maker
Sep 24, 2006
123
BC , Canada
thank you ...
so .. more ..
fuel rail is buttoned up , and also center gasket
timing gears are installed "correctly" and belt installed .
also thermo housing .
exhaust manifold , and shields .
front cover
and the upper intake ..
just about done , and ready for my TRUCK :)
