My build thread!!!
1_slo_92
145
Hillsboro Ohio
Figured I would go ahead and make one while I work on the car this winter. Hoping to get it all finished by spring (besides the paint/wheels)
What I'll be working on:
.57 trim turbo
Maft-Pro
Electronic Boost controller
Wideband
and hopefully some other "go fast" goodies.
Heres what im working with already.
Motor:
.40 Toyota pistons with Toyota rings
New Toyota main and rod bearings
New rod bushings
ARP main and rod bolts
New Toyota water pump
Newer belts
New timing belt and tension spring
New thermostat and radiator cap
New Toyota oil pump
All new seals and gaskets
New Pass. Motor mount
New power steering pump
New upper and lower radiator hoses
New oil overflow hose
4 puck clutch w/ new TOB assembly
Fidennza flywheel
Rebuilt master and slave cylinders for clutch
Mobil 1 10W30 synthetic
Relocated oil cooler
Relocated coolant overflow
Silicone vacuum lines
Head:
3 angle valve job
New Toyota valve seals and springs
2.0 Titan MHG w/ ARP bolts retourqed
NA cam shafts
New heater union and hose
EGR eliminated
A/C eliminated
NGK 1 range colder plugs and wires
Fuel:
255LPH Fuel pump
Aero Adjustable fuel pressure regulator w/gauge
FPD removal kit
Newer fuel filter
Nothing but high octane used at all times
Cleaned stock 440cc injectors
Turbo:
Upgraded ct26 done by Stevevangst never put a BC on it.
Larger front mount
Custom IC pipes. 2.5” steel lower and 2,5” aluminum upper w/ rolled ends and silicone couplers
Turbo XS RFL BOV
Apexi intake
Catch can
Electronics:
Black SAFC2
Autometer EGR,boost, and A/F gauges
Greddy TT
CD player w/ AM/FM
Pioneer speakers
Power antenna broke but in the up position
Silverstar headlights
Dual electric fans
Suspension:
Tokico Illumina 2’s all around w/ new bump stops
Eibach springs all around
Front Greddy STB
stock sawblades with decent tires
Brakes:
Newer stock front pads and rotors
New stock rear pads and rotors
New stock e brake shoes and assembly
Body:
Newer targa seals
Newer front and rear seals for targa
Newer rear hatch seal
Knock sensor rewire
Exhaust:
Titan Motorsport Downpipe 3”
Titan 3” test pipe
Blitz 3” Nur Spec catback
Now with the body im planning on new trim peices (not installed untill paint though, the panels at the bottom of the front and rear fenders. Also fixing the rust/dents and laying the whole car in primer. I also need to get my new pass. door hung before spring.
1 more thing that I will be working on is a cage for the rear. Not looking for one up front right now since this will be my weekend cruiser/racer but I will need a little comfort on my way to the track/car shows.
Interior im looking for a nice looking (nothing drastic) steering wheel, and a nice set of racing buckets so I can fab up the brackets and get them in with a center bar on the roll cage for some 5 point harnesses. Deleting the rear seats also.
Heres a few pics from when I parked it for winter. This is what i will be working with. http://www.imagestation.com/album/pictures.html?id=2100877460
1_slo_92
145
Hillsboro Ohio
Goals as of .57 trim well no goals really Im going to actually push it to see what she can hold. I know it's around 400+ but what is really plus?
Heres some little updates of what I did last night. Just really got it all out and lying on the ground. Im probably going to take off the front end within the next week to spray it. (The fenders and doors are already finished)
But as of last night I took all the turbo/harware out (DP, intercooler/piping ect.) and I ditched the catch can. Im also working on the wiring harness right now. Trying to figure out a way to "tuck" it behind the motor on the firewall so it's not up top in that noticiable of a place. But I don't want to worry about the heat getting at it. Might get some fireproof hosing and split it open and lay it over the front of the harness if I can't get it in a "good" location to me.
Will start on coil packs tomorrow night. Forgot to mention im moving them to firewall.
But anyways heres the pics. If anyone can point out what the hell that hose with thats capped off is please inform me. It was done before I got the car but im not sure what it is. Oh it's on the backside of the pass side of the block.
1_slo_92
145
Hillsboro Ohio
just some pics of the intercooler and if you look closley at the left side of the pic that is oil draining out of the intercooler!! Can you say bad seals?! There is the hose pic, and also the pic of where the charcoal filter used to be. Pretty pointless but o well thats what I have done in 2 hours last night. Heres 1 more of the upper piping, Hopefully I run into some loot soon so I can go ahead and get my MAFT-PRO here. Anyone know how hard the install is?
1_slo_92
145
Hillsboro Ohio
Thanks man, figured I would keep it and hopefully 1 day run at least a 10sec 1/4 mile run. Then I'll be so scared of it, that I will drive it maybe twice a year LoL jp. We'll see where it takes me. I'd love to keep it and hand it down to my son one day but only time will tell. Have to watch the other dumba$$'s on the road to make sure she survives that long.
1_slo_92
145
Hillsboro Ohio
Looks like I have had a change in direction. Im not going with the .57 trim anymore. Im now shooting for 500+WHP!!! will update when I find some hard info to give you guys!
