so started with an 88 7mge auto supra, that got old after about a year so now i am going to a 1jzgte with automatic(for now, one day 5speed)
I got bic mounts and once i figured out what holes they go in, they fit great.
I am having trouble figuring a few things out even after spending hours searching. My 1jz is from a jzz30: rear sump oil pan without TRC and has the 4 row ecu pins. Where is the map sensor for the ECU located? Is it in the manifold? what is it near? I want to make sure it will run when i turn the key, just want to make sure i have this correct. I am going to use an aftermarket boost gauge, eliminating the need for the second map sensor that is normally mounted on the fender. Is that right?
Thanks for the help, im sure ill have more questions as I get closer and closer to starting the engine, but the MAP sensor issue seems to be my first stumbling block. Also some wires were burnt on my harness, the ones for the sensor on the oil pan. If i just cut them, will it still run? I am just using the ma70 dash with no speedo and will modify the tach driver board.
thanks for the help
mike
thanks for the help
mike
