D
drumminforev
Guest
Well i found an 87 na supra for $450. Supposedly he blew it up, but first the guy was saying it was siezed with a melted piston, then he said the rods were bad, then he sayd he didnt know.
Regardless i bought it, and there is oil all over the engine bay.
It wouldnt crank over so i replaced the battery and it started right up to my amazement. Then i remembered that there was no oil or coolant in it so i quickly shut if off.
I checked the remaining oiil that was in it and it is a milky grey color, with minimal viscosity and no smell, so im thinkings its water/coolant, which is bhg right?
It didnt have rod knock, it ran on all 6 cylinders. So i think at this point im going to drain the oil and replace, drive and check the oil again. Likely to replace the hg.
Will i need the head and block resurfased and measured? Im assuming yes.
