hey guys! I'm coming from the lexus community; my past cars were a sc300 w/ gt3071r, then a sc400.
now onto the supra... well i just bought my dads supra which has been in the family since it was on the lot back in '88. my car is a '87 8E3 7mge auto MKIII. one weird thing i thought about it is it has the sport package of ABS and the LSD. but it wasn't equipped with the TEMS. anyways, it did have a BHG at ~50k miles, pulled it out and swapped another 7mge in it. the chassis now has 59k miles while the original block is being built. as you already know the block has 50k on it. my build?
mechanically and electronically, 7mgte na-t, using the same head, and block with na pistons.
work/part list:
bearing clearances check
main king bearings
rod king bearings
honed cylinders
lapped valves
valve stem seals
full gasket and oil seal replacement
NPR 1st, 2nd, and oil rings
NGK copper 2330 plugs gapped at .30"
NGK blue silicon wireset
HKS 1.2 MHG
arp studs @ 95 FT LBS
failsafe thermostat 160*
7mgte mt harness
7mgte mt ecu
7mgte cluster
7mgte cams
7mgte upper intake manifold
7mgte full oem intercooler system
7mgte tb
7mgte tps
7mgte iacv
7mgte cps
7mgte 3000 pipe
7mgte cam covers
7mgte turbo manifold
7mgte intake system
7mgte 440s
7mgte Igniter
7mgte Coil Packs
7mgte oil filter bracket
7mgte oil cooler
7mgte oil cooler return fitting
7mgte power-steering reservoir and bracket
rebuilt ct26
r154 with driveshaft
stage 3 pp with 6puck clutch
my r154 hasnt been able to shift so i cracked it open and checked things out. ended up replacing them along with new seals and a few MC parts.
some electronics
got the r154 back together, shifts really smoothly now.
same day i got my clutch kit from the mail:
stage 3 heavy duty pressure plate (seems to be from toyota?)
"miba" 6 puck copper ceramic, sprung
nachi bearing.
oil return bung welded, water outlet welded, oil fittings and lines made, fitted.
welded up my mounts. im cheap.
shortened shifter by 1"-1.5", clutch master, slave, and ss braided clutch line.
clutch disk, pressure plate, r154... installed
got lots of work done today, figured out the vacuum lines, hoses, gte dipstick, turbo mounted, oil feed and return lines installed. tranny mount installed, etc, etc.
i then realized my oil return bung was siting right above the full oil level, just to be safe i moved it up, only downfall is that i have to rotate my mount if i want to remove the oil return line on the bottom.
work/part list:
main king bearings
rod king bearings
honed cylinders
lapped valves
valve stem seals
HKS 1.2 MHG
7mgte mt harness
7mgte mt ecu
7mgte cluster
7mgte cams
7mgte tb
7mgte tps
7mgte iacv
7mgte cps
7mgte 3000 pipe
7mgte cam covers
7mgte intake system
7mgte 440s
7mgte Igniter
7mgte Coil Packs
7mgte oil cooler
rebuilt ct26
some electronics
nachi bearing.
