My 7M Blew A Head Gasket! :)
iMod
136
Centralia/Chehalis
My Supra blew a head gasket a few months ago, right when I got a new job. I was working 80 hrs a week and so I didn't have any time to work on it. Plus I was afraid to take off the head since I've never gone that deep into the engine before. I had only taken off the valve covers to change the valve cover gaskets.
I took the head off last weekend and it was actually very easy. Only took 3 hours. My friend was helping me though so I didn't mess anything up....I hope....lol. That's the only reason why I didn't wanna take off the head. I plan on doing a big build. I considered the 2jz but I think I wanna stick with the 7M. I haven't put much thought into it yet though. I'm taking the head to get ported and polished soon. I'll be getting new cams, valves and valve springs.
Anyways if anyone has tips or anything like that go ahead and let me know. Quite frankly working on my car is just a hobby and I don't know a whole lot about cars so any advice anyone could offer would be greatly appreciated. My best friends are helping me get it all built up and stuff. I'm looking for about 750hp. I'd love to get the car to showroom quality so I could get it into a magazine. I never see MKIII Supra's in magazines so that's sort of a goal of mine.
92nsx
2,957
Clearwater, MN
I will not make a comment about the 750 or the magazine, but as for you BHG make sure your deck and head are as straight and smooth as possible, if you are going to go with a MHG. Also with the head off this is the best time to do any upgrades to it, if you want.
Plan on a few thousand bucks if you want the rebuild, P&P,cams, valves, springs, & retainers not to mention the labor on the head. Also get your self a a set of ARP head studs when you put it all back together;)
O-ya I almost for got you get this also ::bhg:: LOL.
iMod
136
Centralia/Chehalis
yea that's why I planned on doing all that work, cos I realised that with the head off I can actually do quite a bit. I plan on taking the head and the block to a shop to make sure they weren't warped or anything like that. I doubt it though. The head gasket blew while it was idling and the temp gauge didn't read over half hot. I know it sounds like a lot of work and I probably won't get it all done but it's something I've wanted for a long time.
92nsx
2,957
Clearwater, MN
LOL, sh@% my head off my supra had NO BHG and was rebuilt 5k miles before I got a hold of it to do my entire rebuild and it was off by 7 thou. from corner to corner.
And it dosent sound like a lot of work to me. I have done it a couple times and this time I did everything right the first time (i hope)
iMod
136
Centralia/Chehalis
How is Brian Crower merchandise? I've found cams, valves and springs that are Brian Crower but I don't wanna buy it till I get some feedback and look up some reviews.
figgie
Twin Cities, Minnesot-ah
they are good but should be one of the FINAL things to "upgrade"
Turbo, fueling, exhaust should be touched first.
iMod
136
Centralia/Chehalis
I planned on working on the head for now, then the block, pistons and all that then when the head and block are re-attached then start work on turbo, fuel management, and exhaust.
sneakypete
Regular Member
Jul 18, 2007
1,129
Central NJ
^^^ i second that
for your goals, plan on spending around $5-6 K for all the machining and new parts..... if you plan on doing the bottom end and do most of the reassembling yourself. might be more if your planning on a professional P&P.
just remember to take you time and work slowly so things are done right. dont cut corners and be sure to replace those small but vital components while you have to motor out (oil squirters, fittings, orings, etc). and most of all, do all your research before you start... it will save you time and headaches.
-pete
It's far easier to make power using a well chosen set of cams.... :nono:
Most of the "A 7M doesn't needs aftermarket cams" bullshit goes back to the old days when there was nothing readily available or affordable.
ANY engine can be optimised with a good Cam set.
Rennat
5psi...? haha
Dec 6, 2005
2,844
Tracy, CA
true, but i think its a lot easier to get a 7m up and running on stock cams, and THEN once its built and what not to just swap the cams, it doesnt take very long to get the valve covers off or get the timing cover off...
just my thoughts on his car...
jdub
Feb 10, 2006
10,730
Valley of the Sun
Given enough $$$, quality parts, and attention to detail it is attainable.
Go cheap and take shortcuts and the result is not so good.
Rennat;1108930 said:
to each our own i guess.
and hes 'talking' about 750hp... he makes it sound likes its nothing and can be attained so easily.
Why on earth are you giving someone advice on a 750hp build dude?
Seriously ....
You had to ask advice on guides and seals.
Everyone is entitled to their opinion but you post as if it's an absolute.
"Stock Cams" are a 10 years ago thing when there were NO alternatives or the very few options were damn expensive.
Today there's no reason whatsoever not to install a good set of cams and reap the benefits.
How many of the 7M big dogs are still doing it on stock cams?
Zumtizzle
Can't Wait to Be King.
Oct 21, 2006
2,825
Sac-Town, NorCal
:rofl:
I saw this thread.
Read through it and went ehhh. I'll let someone else take care of it.
For those who don't know. The 7M Cams NA or Turbo are a Joke. ;)
Like the 1JZ you will see massive gains with aftermarket camshafts.
