My 2JZ 86.5 Buildup
The Reaper
Single, and lovin' it!!
Jan 10, 2006
1,909
Florida
well the time has come to part with the 7M its been a blast and its taken a beating and i've done my share of BHG repairs :icon_bigg but it is now time to part with it
i will be going with an aristo 2JZ swap and will begin the swap in the next few weeks CAN'T WAIT!!
while the engine is out of the bay i will be repainting the bay, im trying to decided between the Black Onyx color (black with a little redish gold flakes in the paint) or Evo MR Graphite Gray Pearl. i haven't quite decided yet..then i will eventually be getting the whole car painted to match....
tissimo and i will be performing the swap along with his dark green mica DD, so it should be alot of fun and a GREAT learning experience
before the engine is dropped in i will be replacing all seals and gaskets and MAYBE the bearings....haven't quite decided on the bearings yet.
painting the block black and putting it all back together..
i will be sticking with the stock twins for now to see what they are capable of and then moving on to a single.
im a whole $400 away from ordering my engine and i can't wait for the day to come!!!
i will keep you all posted as tissimo and i go thru our swaps and we will have MANY pics i'm sure!!! :naughty:
take it easy fellas!!!!::w00t::
suprastanger507mgte
2x88+2x89+1x91+2x92=ME
Hayward , Ca
Are you going to use the Aristo wiring for that and mating it to the MKIII or are you going to run a stand alone?
Reason I ask is I am planning to go 2jz in the future > I have a 1jz atm and want to just buy a long block with intake and and accessories. Throw on a single mani and run it off the 1jz electronics.
Not sure if the 1jz electronics will wourk with a 2jz...It should..]
I hope you post a lot of pictures and build information here when you start the project.
Moe.
The Reaper
Jan 10, 2006
1,909
Florida
yea im gonna use the Aristo wiring and Tissimo will be using the 1JZ wiring
check out his build up thread
suprastanger507mgte
Hayward , Ca
Tissimo is using 1jz wiring? Sweet deal. Thanks for bringing that up. I will check out his thread.
BTW: I just secured myself a 2jzgte block : :)
How long are you planning to spend on the swap ?>
The Reaper
Jan 10, 2006
1,909
Florida
well tissimo's will be sooner then mine as he has more money to spend
but i might be getting a bonus check here in a week or so.......so i'd say a month maybe
The Reaper
Jan 10, 2006
1,909
Florida
hahahaha yea but im not too sure yet as you can see i changed my name
the reaper is what im going with so i want black but not just black
black is boring after awhile i want some sort of bronze gold or red flake in it as well...
what stock car has this hahaha so i can get a paint code????
foreverpsycotic
Back in the game!
Jul 16, 2006
3,171
12
ATL
Moe.
just put the 2jz bottom end under the 1jz head. i have heard that there is no difference in the heads. 1.5jz FTW. yay, less work.
/jack
The Reaper
Jan 10, 2006
1,909
Florida
well tissimo got one with 92K on the dial for 1690 shipped to his door from JHOT
i will be getting one from them as well...
1.5JZ is good but the 2JZ head does flow just a tad bit better some here or on SF has bench flowed them and the 2J came out on top
