my 1990 2jzge-t in action
OUCH........thats not suppose to happen............:cry:
Where's the rest of the video where you go by him like he's tied to a tree?
hottscennessey
DONT BE A BITCH!
Jun 3, 2005
3,137
Richmond, VA
X2.
Are you still retarding your base timing, or am I confusing you with someone else?
I know he's got a larger turbo setup, but he's also on a JWT "tune".
If you are. Retarding your base timing, and adding methanol, you're killing your power..
My personal experience is in this thread:
http://www.supramania.com/forums/showthread.php?t=88074&highlight=methanol
juhanis
2jza70
Jan 11, 2006
136
Los Gatos, California
hottscennessey;1241117 said:
X2.
it was me you're thinking of, i know i am retarding timing. i actually killed the rings and one piston on that engine. but that was at roughly 20psi... so, i'm at 10psi currently, and 5 degrees btdc. its safe and its able to hang with, if not beat ~350whp cars. so, when i get my tt gasket in, and a standalone. i'll start making more power. meanwhile i'm enjoying reasonable power, reliability, and pretty good gas mileage. plus, you can hear in that race something happened to my car when i went into 4th. i think it was either the clutch slipping, or the tires spinning. my methanol kit is currently disarmed, btw.
juhanis
2jza70
Jan 11, 2006
136
NashMan;1242145 said:
umm u miss shifted
oh, i made that shift. something wasnt holding. because when it hit the limiter, i went back into it, and i never touched the shifter during all of that. oh well, i thought it was good that i pulled him that hard at the beginning. if there were no mishaps, i probably would have kept him back.
