Flaming River 79-93 Quick Ratio Mustang Manual Rack
Note: Would recomend getting the 20:1 ratio vs the quick rack, unless you have big arms, or you're gonna get some big ol ape arms if you go the quick rack way.
http://www.flamingriver.com/index.c...ategory_id=68/home_id=63/mode=prod/prd337.htm
Borgeson 9/16-26 X 3/4 Smooth Bore U-Joint
http://www.borgeson.com/xcart/product.php?productid=8&cat=5&page=3
New inner tie rods and outers. Right now I'm using 2 drivers side inners. I ordered 2 passenger side ones since they are a little longer. Only have about 15mm screwed in on the drivers side so need to go longer there.
Step 1: Rip out the power rack and all associated power steering stuff.
Step 2: While waiting for your new steering rack to arrive take off your intermediate shaft off the steering column. Cut off the U-joint that connected to your supra power rack. Find a pipe thats 3/4" OD and slip it inside the u-joint. Tac weld everything together and drill your holes. I used grade 8 bolts nuts and lock washers. Now weld the u-joint and lower shaft together. I did a 2 pass weld and left that 2nd pass pretty sloppy.
Step 3: Now you got your manual rack. Remove the boots and buy a BIG ASS wrench. Take off the inner tie rods and put on the supra ones. Put the boots back on. Trim to fit with a sawzall. At the very minimum your gonna have to remove the mustang mounting holes.
Step 4: Install that bad boy. Your on your own here to align it up.
Step 5: Install your outer tie rods. I used the old outer tubes as extenders with a threaded shaft off one of the old innners. Last step here is centering the steering wheel and sliding that new u-joint on the pinion.
